Strange earthing goings on
F
F Murtz
Was just in the shower,feet on the wet tiles water all over me and I got
a tiny tingle through a cut in my finger on the tap handle.
So I plodded through house and got an analogue multimeter, back to the
shower, set meter on 10 volts ac, shoved one probe into wet leg and
other on tap handle,2 volts deflection, strange.
After shower I tested between metal floor waste and tap 5 volts.(floor
wastes are not connected metallically to anything but are wet)
Tried between water pipes at heater, nothing,the earth is bonded to main
water copper pipe there is an earth connected to a stake, have not
measured stake resistance but weather has been wet lately so should be
all right.
Might be some nylon olives some where (not at heater anyway (copper olives))
The off peak power was on to the heater at the time.
Might do some Sherlocking tomorrow or sometime.
Y
Yaputya
F Murtz said:
Was just in the shower,feet on the wet tiles water all over me and I got a tiny tingle through a cut in my finger on the tap
handle.
So I plodded through house and got an analogue multimeter, back to the shower, set meter on 10 volts ac, shoved one probe into wet
leg and other on tap handle,2 volts deflection, strange.
After shower I tested between metal floor waste and tap 5 volts.(floor wastes are not connected metallically to anything but are
wet)
Tried between water pipes at heater, nothing,the earth is bonded to main water copper pipe there is an earth connected to a stake,
have not measured stake resistance but weather has been wet lately so should be all right.
I had something similar happen several years ago, although the cause is unlikely
to be the same as your situation unless you have old house wiring.
I got a tingle in the shower from touching the taps, it was fairly strong (I was wet)
so I got out and checked it with the MM. It measured around a hundred volts AC, but
only a few mA on AC current.
The cause was discovered after we called in a sparkie - the shower had a lead sheet
tray underneath it which folded up at the sides to contain the shower drainage.
One side of the sheet went up the wall cavity and there was a GPO in the next room on
the other side of the wall which had rubber-sheathed wiring. The edge of the lead sheet had
started to cut into the old rubber insulation - which was old and very brittle. Murphy's
law meant the first wire to be affected was the active, of course. There was enough
resistance to limit the current, another mm or two and it could have been fatal.
F
F Murtz
In my case the shower tiles are on a concrete floor, the whole house is
on a concrete slab.
atec77
all right.
olives))
Sounds like a neutral reversal
do you have a gpo tester ?
X-No-Archive: Yes
Peter Johnson
"F Murtz" wrote in message
shower, set meter on 10 volts ac, shoved one probe into wet leg and other
right.
olives))
One thing that can cause this is a broken neutral so ground ends up being
the return path. Here's a bit of a description:
http://www.electronics-tutorials.com/basics/earth-dangers.htm
You need to watch it because a slight tingle can turn fatal quickly
depending on the impedance, which of course things like moisture and
physical impacts can affect.
F
F Murtz
being the return path. Here's a bit of a description:
In my case the taps seem to be at earth potential. it seems that there
is a potential difference between the copper pipes and the shower floor
on the concrete floor slab.
