Hello All
I have this BLDC project and have chosen to use the Silocon Labs SI8233BB isolated drivers.
I am getting this strange stepped waveform on the rising edge of the PWM, has any one seen this before and know what might be causing it?
The drive is bootstrapped with 3 fets in parralell, each with its own gate resistors and diodes. The waveforms were taken with the motor running no load with only around 0.3A current from the PSU (about right for this motor). The fets are FDP61N20 and the bootstrap caps are 470nF each.
I had all three SI8233BB fail (Now repaired), do you thin this could be causing the problem?
