Stopwatch circuit with milliseconds
Hi
I am looking for an accurate Stopwatch circuit with a time resolution of 100ms.
The display is required on 4-digit or 2x2-digit 7-segment LED.
Maximum time 99 seconds.
The circuit may be with or without µC or Arduino.
I prefer separate buttons for Start and Stop but a single button is also acceptable.
I Googled but could not find some suitable option.
Lots of these are Available on Ebay, From China with free shipping.
Many Under $10
Not as Kits, but you can't beat the Price.
Any timer displaying 'seconds' could be readily adapted to mS simply by changing the programmed divisor that produces the 'count' pulse.
In the case of a discrete construction this would mean (for example) leaving out the last divider in the timing chain and getting 1/10th second (or leave two dividers out to get 1/100th second etc) pulses.
"The display is required on 4-digit or 2x2-digit 7-segment LED.
Maximum time 99 seconds."
Sounds like a class assignment.
Ken
Ken
Of course, not.
I need it to integrate it in my project. First I was thinking of utilizing some cheap stopwatch and it was fairly easy to adapt. But I gave up only because of the tiny digits. I decided to built my own circuit but I don't have experience of working with 7-segment LEDs. So I am seeking help here.
I found a lot schematics but almost all of them have 1sec time resolution or displays without the decimal point. Also I have very little experience of programming µC or Arduino.
And by the way, maximum time is 60 seconds (not 99 seconds, my mistake)
The decimal point can be simply hard-wired 'on' as required.
Find a circuit that uses (say) a 1MHz crystal and the 4017 decade divider (or the 7490 - old-school stuff) but instead of dividing the signal down to 1 second intervals simply tap the clock off at the 1mS interval (1kHz point).
1MHz (xtal) divide-by-10 = 100kHz
100kHz divide-by-10 = 10kHz
10kHz divide-by-10 = 1kHz (the mS timing range)
and so on
1Hz - the 'normal' signal used to count seconds.
Many such circuits are designed as frequency counters - the 7490 was a classic for this, used in conjunction with the 7447 BCD-seven-segment driver. Should be loads of schematics on the interweb.
