Hi! I modified the following program to get a pulse of 5V and 40kHz of frequency. I tried it in an oscilloscope and I get a 4V pulse and 12,8kHz frequency. What is wrong in the code??
Thank you
Code:
#include "stm32f4xx.h"
#include "stm32f4xx_rcc.h"
#include "stm32f4xx_gpio.h"
#include "stm32f4xx_tim.h"
void TM_LEDS_Init(void) {
GPIO_InitTypeDef GPIO_InitStruct;
/* Clock for GPIOA */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
/* Alternating functions for pins */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_TIM13);
/* Set pins */
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStruct.GPIO_OType = GPIO_OType_OD;
GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_Init(GPIOA, &GPIO_InitStruct);
void TM_TIMER_Init(void) {
TIM_TimeBaseInitTypeDef TIM_BaseStruct;
/* Enable clock for TIM13 */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM13, ENABLE);
Set timer prescaler
Timer count frequency is set with
timer_tick_frequency = Timer_default_frequency / (prescaller_set + 1)
In our case, we want a max frequency for timer, so we set prescaller to 0
And our timer will have tick frequency
timer_tick_frequency = 84000000 / (0 + 1) = 84000000
TIM_BaseStruct.TIM_Prescaler = 0;
/* Count up */
TIM_BaseStruct.TIM_CounterMode = TIM_CounterMode_Up;
Set timer period when it have reset
First you have to know max value for timer
In our case it is 16bit = 65535
To get your frequency for PWM, equation is simple
PWM_frequency = timer_tick_frequency / (TIM_Period + 1)
If you know your PWM frequency you want to have timer period set correct
TIM_Period = timer_tick_frequency / PWM_frequency - 1
In our case, for 40Khz PWM_frequency, set Period to
TIM_Period = 84000000 / 40000 - 1 = 2099
If you get TIM_Period larger than max timer value (in our case 65535),
you have to choose larger prescaler and slow down timer tick frequency
TIM_BaseStruct.TIM_Period = 2099; /* 10kHz PWM */
TIM_BaseStruct.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_BaseStruct.TIM_RepetitionCounter = 0;
/* Initialize TIM13 */
TIM_TimeBaseInit(TIM13, &TIM_BaseStruct);
/* Start count on TIM13 */
TIM_Cmd(TIM13, ENABLE);
void TM_PWM_Init(void) {
TIM_OCInitTypeDef TIM_OCStruct;
/* Common settings */
/* PWM mode 2 = Clear on compare match */
/* PWM mode 1 = Set on compare match */
TIM_OCStruct.TIM_OCMode = TIM_OCMode_PWM2;
TIM_OCStruct.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCStruct.TIM_OCPolarity = TIM_OCPolarity_Low;
To get proper duty cycle, you have simple equation
pulse_length = ((TIM_Period + 1) * DutyCycle) / 100 - 1
where DutyCycle is in percent, between 0 and 100%
50% duty cycle: pulse_length = ((2099 + 1) * 50) / 100 - 1 = 1049
Remember: if pulse_length is larger than TIM_Period, you will have output HIGH all the time
TIM_OCStruct.TIM_Pulse = 1049; /* 50% duty cycle */
TIM_OC1Init(TIM13, &TIM_OCStruct);
TIM_OC1PreloadConfig(TIM13, TIM_OCPreload_Enable);
int main(void) {
/* Initialize system */
SystemInit();
/* Init leds */
TM_LEDS_Init();
/* Init timer */
TM_TIMER_Init();
/* Init PWM */
TM_PWM_Init();
while (1) {
Thank you
