Hi everyone, i posted three weeks ago about full bridge rectifier circuit "overheating of compenents problem" (diodes, mosfet, resistors), so im still suffering with this circuit,
i have old induction motor 220v/380v, it has a two electromagnetic coils specialised to pull a two metal cylinders, one coil pull one cylinder to connect it to the main rortor of the motor to make it rotates and the second coil pull the other cylinder to connect it to a fixed cylinder to make it stop, and these two coils work alternate,
and i believe that these two electromagnetic coils works with around 20v on DC power, because the motor had a complex circuit do Multiple tasks that is now broken and i dont need all those tasks now anyway, also it has a transformer 220v/24v and i didnt noticed when i posted my previous post that there is the amount of amperes written in transformer, it written "96 VA" if im correct it means 96 amperes,
so the problem that im facing is to convert the AC output of transformer to the DC without overheating of compenentes and without lossing power,
i tried anything according to my humble knowledge,
when i decrease the current the power become very weak and electromagnet is useless, and when i increase it the components start burning,
when i put high value resistors nothing changes in the decrease of current and when i put low value resistors they start burn,
i maked a transformerless circuit to decrease power, its input connected to the output of the main transformer and its output connected to the bridge rectifier input, and the result is very, very weak power that does not actuate the magnet, so i started to think of a way to increase it, so i connect another step-up transformer to the transformerless output and the result is no power at all in the step-up transformer output,
so i started to think of another way to feed the output of bridge rectifier connected to transformerless using mosfets to take power directly from the main transformer AC output to drop it in the output of the bridge rectifier using diodes, and two resistors and capacitors in series through each two gates of mosfets,, and the result is very very low increasing change, it almost nothing, but when i gived more power to the two mosfets gates by decreasing the value of resistors the power increased but again these mosfets begins overheated,
so no matter what i did always i end-up by one possibility, either i decrease power to prevent components from burning but the magnet coil will be useless or i make proper power for it but the compenents start burning,
now im thinking to build AC to DC to AC to DC circuit (multivibrator and switch mosfets), im thinking to decrease the bridge rectifier output power using resistors then converting it to AC then step-up it using transformer then converting the output step-up transformer to DC,
i drew the diagram of this circuit, so i would like and appreciate to hear your opinions and advice about this circuit, if it is correct or false,
and this is the link of my previous post : https://www.electronicspoint.com/fo...ut-full-bridge-rectifier.296879/#post-1826640
thank you all.
thank you all.
