I start new project name as "digital display sterio woofer". we can supply a signal from audio source and from MIC too. we add equalizer for each signal and mix signal of sterio(audio and mic input). so that it become complicated.i use bjt as preamp of mic and to mix signal i use buffer using op amp741,equalizer also using opamp 741. this circuit work properly but problem is in power amp, i use sterio ic 2822 as power amp i also work in audio input but it makes very noisy sound when its connected to MIC input. i thing mic peak noise or problem in power amp part so pls .... suggest me where i have to change ???
one confusion !!! can we drive sterio ic as mono mode by using single switch?? but loudness of speaker must not change.
