Hi - this is my first post and I found the forum just from google. Looks pretty good and as I sometimes dabble with circuitry could be just the very thing.
I have an oscilloscope, a dmm, and a soldering iron I have been into electronics since I was a kid.
On to my current problem...
I've got a stereo power amp - in fact it is a Marshall 8008 mosfet output stage thing for guitar. The fault is as follows...
With input A connected
Channel A level control sends output to B only, loud.
Channel B level control sends output to nothing.
With input B connected
Channel B level control sends output to B only, even louder.
With input A & B connected
BUT here is the weird thing ... as per the last scenario (both inputs A&B connected) you can get quite a bit of volume out of both sides IF you balance the level controls in just a certain way (roughly so that B is 30% higher than A).
So... dead channel A or what? I would have expected just to not get anything out of which ever side was dead, and also taking into account that either input A or B would expect to be able to use as a single channel input, outputting to both sides.
If anyone can tell me where to start, I'd be grateful - a visual inspection of the underside of the pcb didn't reveal anything except the fact that someone else has been over it for dry joints in the past... possibly in an attempt to repair the current fault.
thanks!
thanks!
