Jamie
I'm looking into getting a good microscope
for bench work. I've decided it's time to upgrade
to something with a lot more zoom on it other than my
cheap over head boom arm 5x with light.
I've looked at stereo scopes that do up to 47x with
a boom arm that can be attached to the bench..
Can any of you offer any suggestion of what you maybe
using at the time ? I really don't want to break the bank
for something that I may only use once a month.
My eyes aren't that bad yet how ever, the scale of
components for things like hand held radio's are small.
I've even had to custom make some desoldering tips on
my lathe for some applications. My hot tweezers only work
for something's.
I still remember the last tip I made, 45 degree angle.
after drilling pump hole. I then squeezed the end to make it
wide and flat with out closing the hole! that was a trick.
With a little surface grinding it looked good, then
I plated it.
for something's.
I plated it.
