1. Hi, can any one help with a compact design of a circuit to step up 5 volt dc to 72 volt minimum (upto maximum 90 volt ).
2. Output voltage can be dc or ac. It's a low current design with a maximum current need for the load is of 50 milli ampere only.
3. Input 5 vdc will be taken from mobile phone backup powerbank. So, even if the powerbank voltage drops below 5 vdc the ckt should work and give a minimum output of atleast 72 volt ( dc or ac)
I need a functional ckt with a small design. Your help is much appreciated.
