I am a total noob to this and I am hoping I can get a little help here. Here is what I am trying to do. I have an older quad motorcycle it has no battery so it gets electrical power from a stator. I like to do a lot of night riding but the problem is the headlight isn't bright enough. So what I would like to do is make an LED headlight that will put out more lumens than the standard 35w bulb. I thought about adding a battery but there really isnt much room. Here are the specs for the stator.If you put a voltage meter on the stator lighting circuit, it will usually make about 50 volts AC at high RPM without a load on the system. If you check the voltage out of the voltage regulator without a load on the system, it will usually be about 13 to 15 AC volts. Any ideas of how this can be accomplisheb. I really appreciate the help. Thanks
Platforms
Content
