steamer
--There's a site up with an excellent description of how to build a
tach with a Basic Stamp, at:
http://www.floridaame.org/Plans/Kamran Nili/rpm/tachometer.html
I built this circuit the other day, then had an expert pal make sure
I hadn't done anything wrong (left out one wire!).
Once all was set to rights I tried the three programs to see what
would happen.
First one: got some readings on the debug screen when waving a
magnet back
and forth near the sensor: a good sign, yes?
So then I loaded the second program and got the proper responses
from the display, so all was well there.
After loading the third program things started to get weird; i.e.
we were unable to get consistent readings. What I did is tape a neodymium
magnet to the edge of a little 2" sanding disk, chuck it in a small drill
and power it up near the sensor. It seemed to do *something* but not what
I expected; i.e. sometimes I'd get a reading after I removed the rotating
magnet,
but not while it was spinning. I thought maybe the neodymium magnet
was too strong and switched to a weaker one but results were just as
weird.
I'm wondering: might there be a problem with the "flywheel"
being too small in diameter? Don't think this could be the problem but one
never knows.
There were also times when the numbers displayed were almost
random; i.e. readings being much higher than the rate at which we waved
magnets near sensor. It was all a bit baffling.
We're sort of in the dark here, so any clues folks can pass along
would
be greatly appreciated. Thanks,
would happen.
magnet back
magnet,
weird.
never knows.
would
