Hammy said:
Would this actually work?
Stabilizing regulators with low esr output caps (Ceramics and
polymer)
The full note is here. Wayne Rewinkel National Semi
Are there any negatives other then decreased dropout voltage and
power dissipation in the series resistor?
One of the problems with LDO design is the ESR of the output cap
must fall within a certain range for the loop to remain stable.
Here are some comments from a post by Tim Shoppa on using ceramic
caps with LDO regulators. The ESR is usually too low and can cause
oscillation, and the bias voltage on Y5V dielectric can cause a
significant drop in capacitance:
09 Feb 2004 09:14:28
Tim Shoppa
Selecting > 1uF ceramic caps
R. Legg:
The ESR problem with 'LDO' regulators is not one that applies
specifically to ceramic capacitors, or even to LDOs; it's a problem
that applies generally to all regulators with PNP or P-chanel output
pass transistors, due to the added inversion in their control
structure and the capacitive nature of their normal load.
Leeper:
Take a 6V 10uf Y5V, put it on a 5V rail for filtering, and you end
up with an effective capacitance of 1uf.
http://www.avx.com/docs/Catalogs/cy5v.pdf
Here are some articles showing why LDO regulators are sensitive to
output cap ESR. The url's are omitted since they often change, but
google will find them very quickly.
AN1148.PDF 205,195 Compensating Low-Dropout Regulators
AN682.PDF 879,026 New Generation of Low Dropout Regulators
AND8028.PDF 38,766 Precision Sub-One Volt 1.7 Ampere Output LDO
SLVA068.PDF 68,595 LDO Fundamental Theory
SLVA072.PDF 291,538 LDO Technical Review
SLVA079.PDF 202,342 LDO Terms and Definitions
SLVA115.PDF 85,754 Regulator ESR Stability
SLYT151.PDF 468,245 Compensation Transient Response
SLYT187.PDF 254,973 Understanding the Stable ESR Range
SLYT194.PDF 246,355 LDO Linear Stability Analysis
SR003AN.PDF 73,945 Compensation for Linear Regulators
SR004AN.PDF 41,598 Linear Regulator Output Structures
Analog Devices has found a solution to the ESR problem:
"Solving Stability Problems of Low Dropout Regulators"
http://www.analog.com/en/content/0,2886,766_818_11812,00.html
and National Semiconductor solved it also:
"Capacitors are key to voltage regulator design"
http://www.national.com/nationaledge/jul02/article2.html
So with careful design, you can make a LDO regulator immune to the
ESR of the output cap.
Regards,
Mike Monett
