Tony
I know there are optoisolators with zero crossing triac drivers available but
what are the drawbacks of using a small solid state relay to drive the gate of
a triac for increasing the load current. I have an application that requires
six 240 VAC outputs controlled by a MCU. Five are under 1 amp load current. I
have chosen the Omron G3MB -202P zero cross 2 Amp SSR's. The sixth output
requires 12 Amps (resistive heater). Can I drive the gate of a 20 amp triac
with the omron G3MB.? I tested it on the bench with a 100W load and 150 ohm
gate resistor and it seems to work fine.
Tony
Tony
