spot welders for ni cad battery rebuilds.
nick moore
It seems a lot of we DIYers want to rebuild ni cad packs from 12
drills etc.
Spot welders seem to be the ideal method.
Q) anyone out there built / seen/ used a homebuilt version for thi
purpose.?
Normal spotwelders for heavier joins are basic mechanics and electrica
parts.
Combining the knowledge of a group like this should get a basic desig
possible i reckon..
Any ideas out there. I can make gadgets in metal but have no idea r
volts/ amps needed to make the spotwelder work..
RC modellers/ recycler fiends and DIYers would get a lot of use fro
such a machine in a community.
Jewellers use them but high cost. Surely the junk brigade can cover th
problem?
Any ideas appreciated..
Nick Tasmania Australi
spudnuty
This is from a current thread in "basics":
http://groups-beta.google.com/group...to+topics&_doneTitle=Back&&d#d32a8f0214ad3b43
and the DIY spot welder:
http://users.frii.com/katana/spotweld.html
I've done this for a long time. I replaced batteries in pro movie
camera belts but those were soldered together. At least that's the way
we did it. More recently I work on my own stuff, mostly Makita 9.6V
sticks. I've been using a big soldering gun with the tip cut off.
Pressing the open leads against the work firmly makes a lot of cool
sparks but heats the work area so that it takes solder nicely. This
method wouldn't do well around sensitive components. There's another
guy working on heat sinks that uses a BIG iron. I also reassemble the
batteries first and make the middle connection at the bottom last. This
avoids most short circuit problems. I also don't leave out the
cardboard sleeves and the plastic washers between the cells.
Richard
mike
Richard
Short Answer: I've been workinng on and off on the problem for a couple
of decades. Here's the result:
http://nm7u.tripod.com/homepage/welder.html
I stopped working on it when a Unitek CD welder fell into my lap.
Long Answer:
Welding something with an electrode on each side and no worry about
temperature is pretty easy.
Welding with both electrodes one side and not being able to heat the
metal is MUCH more difficult. You need a LOT of power for a short time.
The current has to go thru the contact points and the battery case, not
the metal strip. Nickel is most used, but I've found .005" brass from
the hobby store to work pretty well. Contact area is critical. Too big
and it won't weld. Too small and it burns thru. You're on the right
track when you get a weld that can't be pulled off without tearing the
strip and the battery is still cold to the touch.
One thing that helps is to cut a slot in the tab material between the
electrode contact points. That increased path resistance forces more
current thru the battery. If you cut it longitudinally, you can make
the path length thru the tab arbitrarily long.
If you use a transformer and run if off the AC line, you need to worry
about saturation in the core. I solved the problem by using zero
crossing turn on and running an integral number of cycles.
You can have ZERO.Zero resistance in the welding path. I was improving
the setup by taking out a couple of milliohms at a time. You'll see a
lot of soldering on my system. That's all mechanical. No current goes
thru a soldered joint.
My welds were working but they were extremely sensitive to time,pressure
and number of cycles of AC line. More turns on the scondary gives you
more voltage and less sensitivity to time/pressure, but increases the
input amps proportionally for the same output amps.
Oh, I was sucking 40 amps for six cycles out of a 15A house breaker.
Talk about dimming the lights ;-) I was about to give up and add a
third secondary turn when the Unitek fell into my lap.
The Unitek CD welder is MUCH more forgiving. It dumps a fixed amount of
energy and is relatively insensitive to contact resistance. That's
relatively. Still have to be careful, but I can make 10 good welds in a
row without much trouble. Couldn't do that with the microwave transformer.
Wear safety glasses and an old shirt. A mis-weld sprays molten metal at
you. Keep a flashlight handy so you can find the fuse box when it blows
;-) Blows caustic stuff at you when you blow a hole in the battery.
Been there done that.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
W
worldcitizen
nick said:
It seems a lot of we DIYers want to rebuild ni cad packs from 12v
drills etc.
Q) anyone out there built / seen/ used a homebuilt version for this
purpose.?
Normal spotwelders for heavier joins are basic mechanics and electrical
parts.
Combining the knowledge of a group like this should get a basic design
possible i reckon..
Any ideas out there. I can make gadgets in metal but have no idea re
RC modellers/ recycler fiends and DIYers would get a lot of use from
Jewellers use them but high cost. Surely the junk brigade can cover the
problem?
Nick Tasmania Australia
I've rebuilt nicad battery packs by cutting the tabs that are tack
welded to each individual battery so that there is a long tab left and
then soldering the two tabs flat against each other between the
replacement battery and the old battery left behind. It does not heat
the batterys too much and works fine mechanically.
Matthew Smith
Charlie+ said:
as underneath my scribble :
This tripod site tried to load 32 ads and cookies during the time it
took to load this page - beware.
I'm using Firefox with pop-ups disabled and a Flash-turner-offer
extension; I had no problems at all, whole lot came up in less than
0.5s, albeit on half a meg of ADSL.
However, comment well taken as all Tripod sites seem to "pollute" the
browsing experience unless steps are taken to prevent it.
mike
Where's a good place to stash a FREE webpage that doesn't have ads?
I'd be more than happy to move there.
Popup and ad blockers seem to be a necessity to surf today's web.
mike
NSM
Try your ISP.
James Sweet
mike
There's no free lunch, somebody's gotta pay for the web space.
You *do* need an ad blocker to surf the web these days, I too would strongly
recommend Firefox with the free Adblock extension, you can even import a
large list to Adblock so you don't even have to mess with it, brings the
enjoyment back to surfing the net.
