Spikes on Zener Clamp Circuit
rich
I am using a zener clamp to regulate a messy signal down to a level
that will cause an interrupt in a microcontroller. The circuit works
fine but I am seeing some troubling spikes on the output, both
negative and positive.
The input signal is a reoccurring ~150Vpp ringing signal.
I would appreciate any ideas....
See details at:
http://members.dsl-only.net/~rsoennichsen/zener_clamp.htm
Rich
Andrew Holme
See details at:
Rich
Those spikes look uncorrelated with your CH2 input signal. Do you still get
them even if you touch the CH1 'scope probe to ground at the diode anodes?
In electrically noisy environments, you can pickup huge impulses on a
single-turn loop formed by connecting the probe ground lead to the tip.
You could add a little filtering to your input circuit using series
inductance (e.g. ferrite beads) and/or shunt capacitance.
W
whit3rd
High slew rate signals might result from inductive coupling of wiring
near the clamp. The Zener clamps the conducted signal, but the
wire in series with that signal can couple, as a transformer winding,
to the input.
BobW
See details at:
Rich
What is it you've captured? That signal has a period of 100us (10kHz), but a
standard ringing signal is usually 20Hz.
Bob
rich
I think you may be on to something. I will ground the scope probe
right next to the tip and see what it looks like. The ferrites are a
good idea too.
thanks
rich
Jan Panteltje
See details at:
Rich
Why use a diode? A zener is a diode the other way around.
F
Fred Bloggs
(10kHz), but a standard ringing signal is usually 20Hz.
Bob
LOL- subtle...
F
Fred Bloggs
See details at:
Is it really necessary to dissipate a full Watt to drive a micropower input?
This circuit has a fairly huge working input range of amplitudes it will
handle at your frequency:
View in a fixed-width font such as Courier.
F
Fred Bloggs
. .-------------------> to INT
. | Vdd (5V)
. | D1 D2 |
. sig >-[470k]--+---|>|---+----|<|---'
. [10k]
. D3 | D4
. sig >-------------|<|---+----|>|---.
. com |
. dgnd
. D1,2,3,4 1N4148
Scratch the above. It should be:
Jamie
See details at:
Rich
Hmm, I guess my first question would be:
1.
Are you using a 10:1 probe to measure that?
2. Do you have near by R.F. and maybe the diodes or
uC input is rectifying depending on what side you check?
3. Did you account for parasitic conditions with the construction
of the traces, components etc... ?
P.S.
Zeners are know to be slightly slow. Don't know if this is an
issue on your end but it might be worth looking into?
"I'd rather have a bottle in front of me than a frontal lobotomy"
"Daily Thought:
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT
THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
http://webpages.charter.net/jamie_5"
Joe G \(Home\)
See details at:
Rich
How about an analog scope - could the digital sampling be playing tricks?
joe
