Hi all,
I have been monitoring some SPI signals for a WiFi IC. The device is powered from 3.3V. The CLK frequency is 4.5MHz
However, I am seeing overshoot and undershoot on the CLK, MISO etc
For example on the CLK the overshoot can get to 3.9V. The undershoot is about -0.65V. This could cause potential issues by exceeding the voltage levels for the WiFi I/O pins.
I have two questions
1. I cant see how it is possible to see ringing which is greater than the supply voltage of 3.3V?
2. Its more than likely caused by inductance. I have tried a shorter gnd probe, it makes a difference to the CLK i.e. no ringing but the MOSI and MISO are the same.
Any help would be appreciated.
