Platforms
Content
Most likely just the frequency of the power supply has risen enough to makeBoris Mohar said:
Boris said:
Ken Taylor said:Most likely just the frequency of the power supply has risen enough to make
10 minutes in 24 hours (as it appears to be that sort of period). Any clock
with a mains-derived reference will be affected, whereas the others are
likely crystal controlled and unaffected.
Ken
Way easier to write a startling letter to the Editor.John Larkin said:me=Local+News
These people should hang an oscillscope on the AC line. The waveforms
should be interesting.
John
John Larkin said:These people should hang an oscillscope on the AC line. The waveforms
Looks like generator not at 60Hz, but running fast?
Jan said:Looks like generator not at 60Hz, but running fast?
Are they not locked to an other grid?
Why do they not mention frequency?
Strange.
10 minutes in 24 Hours is 600 / 24 x 3600 6.9E-3 should be 60.41Hz
Did I goof on the math? Probably.
Stefan Heinzmann said:As several people here have noted the fault is blatantly obvious: The
power station failed to control the mains frequency properly. What
strikes me is the apparent cluelessness or incompetence of the power
station staff. I can sort of accept that their spokesman has no clue and
utters the usual bullshit, but their engineers at least ought to have an
idea what they are dealing with.
I hope this is not an indication of the general state of affairs in US
power stations...
I sincerely doubt that Sault St Marie is located in a non-integrated
portion of the power system. Now perhaps Hydro One was doing some sort of
transmission maintenance, temporarily islanded that area and did a lousy
job of regulating the frequency, but I'm still betting on a harmonic
resonance in that area.
What is against harmonics / distortion of the wave form is the rather small difference,I sincerely doubt that Sault St Marie is located in a non-integrated
power stations...
nospam said:Will be a boring sinewave the same as any other.
The real mystery is how people consider something so bloody obvious
to be a mystery.
You are looking at the output of a DC to AC converter?Mine is a series of straight lines approximating a sine wave. About 10
individual lines make a complete cycle, so it's a very rough
approximation.
The mystery is what's causing it. I'd also like to know why mine is
straight lines.
Mike said:I don't know why it should, any more than what goes on in France should
indicate the state of affairs in Germany.
Besides, we can't annex Canada till we're done in Iraq.
The critical question is whether synchronous-motor-type clocks gained
time, or only electronic ones.
John
That is because they last for ever, I bought this one in the seventiesI wonder if anyone still has that kind of clock. I know we don't have
any in our house. The last ones would probably be owned by older
people with even older stoves or stand-alone clocks. I don't think
I've seen them among the retro design items like old-fashioned fans
and such like.
IIRC.
Has an alarm too, and I use it (backed up by the cellphone).
JP
and such like.
Best regards,
Spehro Pefhany
