So I'm having an issue understanding exactly what the issue was with my stepdown converters.
Before I go any further here are the details of the stepdown converters.
http://vi.raptor.ebaydesc.com/ws/eB...363&category=117000&pm=1&ds=0&t=1476497479916
I ran a 120mm fan x2 combo that I scavenged from a server, it also had a rail that had a triple fan assembly. Fans were rated for 12V 1.0A. They are Nidec BETA V TA350DC fans. I also have a TA450DC rated @ 12V (1.40A) And several Delta Electronics DC Brushless MODEL PFC1212DE's, @ DC12V (4.80A)
So I connected the pc fans to a laptop supply that was 12V (2.0A) And drove 2 fans and it seemed to work like I was hoping except that when I would adjust the voltage potentiometer I could only lower the voltage down to about 6 volts maybe it was slightly lower I can't recall exactly now.
I could'nt seem to adjust the current at all which would be obvious because the fan would slow dramatically and the current potentiometer adjusment knob did not appear to be working the way that my circuit was set up. They are 4 wire fans but I was just running the 12v and ground wire.
I believe they have a hall effect sensor and a transistor rpm controller. As far as I know the 2 wire fan circuit can't be overridden by the transistor because there's no power going to the transistor (rpm controller).
I wish that I could upload photos of the converters and fan together but its not really that important atm.
What's of main importance is the led chips I want to drive with a 32V-40V (9.75A) switching power supply. The chips require an input volttage that is lower than the lowest output voltage setting on the power supplies voltage potentiometer. Chips are rated for MAX Approx (91watts) 26V (3.5A).
Assuming the step down converter cannot increase current in exchange for voltage drop I am fine with the 1/4 Amp loss. However its worth knowing whether or not a Buck/Boost Converter would be able to manage the power in such a way to exchange voltage drop for current increase. What I'm definetly not aware of is how the power supply would react to changes one the other end.
When I tried to current test the laptop supply 12V (2.0A) The meter would blip read 1.9 maybe 2.0A and then drop to somewhere like 0.1A in a sec and stay there and when I would stop short circuit current testing the fan would go back to full speed. I'm not sure if I'm current testing correctly, I do know my meters fuse is a 10A fuse, and the output current of the led power supply is 9.75A so I don't want to blow a bunch of fuses over and over again.
I'm assuming the issue with the step down (buck converters) I have with that fan only adjusting voltage down to 50% had something to do with the switching laptop power supply. I really don't want a voltage surge to hit the led chips because they have diodes that have a lower power capacity and will burn out and ruin the chip because of the combination (Parallel single row 10 diodes down) & (10 rows of Series circuits across with 10 diodes each) burning out a row would increase load through others and the chip would eventually catastrophically fail.
Anyhow I'd like to figure out how to upload photos to the thread for the sake of better illustrating what I'm trying to achieve in terms of ensuring the chips get the proper input voltage and don't end up fried and no good to me.
I much appreciate any help I can receive on this matter so I can share the results with other people interested in knowing more about the particular led circuit, the chips themselves, the buck converters, and potentially the light assembly which I have big plans for *Spoiler* It's going to be a recirculating liquid led chip assembly with a fan-cooled radiator to chill the coolant before it flows through the CPU waterblocks bolted to the back of the chips.
Anyhow this is enough information for one post anyways.
