Speaker Resistance Equivalance
W
WbSearch
If an audio device requires 10 ohm speakers, can I use 8 ohm speakers and add a
2 ohm resistor in series, or does it require impedence matching ILO resistance?
Richard Crowley
Maybe. Depends on circumstances. More details would enable
more complete responses.
and add a 2 ohm resistor in series, or does it require impedence matching
ILO resistance?
There is no generic answer to your question.
V
Virgil
I have used resistors in series with speakers in cases like that with no
problem.
Virgil
Sofie
WbSearch:
The difference between 10 ohm speakers and 8 ohm speakers is not a big deal
and most likely the 8 ohm speakers will not cause any problems with your
"audio device".......... and, yes, if you are still concerned about causing
problems your "audio device" then adding a 2 ohm resistor in series with
each 8 ohm speaker (suitable wattage as determined by your "audio device")
will take care of the difference...... your "audio device" will then be
completely happy because it would be seeing a 10 ohm load.
Bear in mind that there is no free lunch...... 20 % of the power from your
"audio device" will be dissipated in the 2 ohm resistor, the other 80% will
make it to the speaker.
Best Regards,
Daniel Sofie
Electronics Supply & Repair
resistance?
jakdedert
Ditto...in any case, there is no such thing as a speaker in which the
impedance never varies from the marked value. IIRC, the parameters are
measured at a given frequency, or are an average.
Move from the given frequency and the impedance varies.
jak
L
Lionel Wagner
No great problem using a resistor. Use a wire-wound, it will be
marginally better by presenting an inductive load, similar to
the speaker's voice coil.
Richard Crowley
like that with no problem.
That is one possible solution. But note that if this is some
high-power application it may not be desirable or even
very feasable.
It is also quite possible that the two-ohm difference doesn't
have any apreciable effect and resistors would be superfluous.
Mr. Search has just not offered enough detail to make any
kind of useful reply.
W
WbSearch
Thanks for the replies, and I do realise my question was very broad,
undedtailed. It was a generic qiestion for my nephew that has an old GM radio
he wants to put in his vehicle.
Sofie
WbSearch:
Forget about the 2 ohm resistor, install the 8 ohm speakers, and enjoy your
"audio device"..
Best Regards,
Daniel Sofie
resistance
W
WbSearch
Will do, thanks. Sorry for the spelling in the previous post. Wanted to get
the message out in a hurry. Won't do that again. Too embarrassing.
Asimov
"WbSearch" bravely wrote to "All" (05 Feb 04 16:02:29)
--- on the heady topic of "Speaker Resistance Equivalance"
Wb> From: [email protected] (WbSearch)
Wb> If an audio device requires 10 ohm speakers, can I use 8 ohm speakers
Wb> and add a 2 ohm resistor in series, or does it require impedence
Wb> matching ILO resistance?
It could be a misprint and it should read 16 not 10?
V
Virgil
If I remember right, some Delco radios used to use 10 ohm speakers.
