I have four infinity speakers.
they all need new foam (maybe).
infinity say they have no replacement speakers (what?) and offered no
repair kits.
i do have a few local places that refoam but have not called for prices
yet.
the speakers still sound fine to me except when there is some low
frequency music that cause the speakers to rattle.
1) what is the purpose of the foam? dirt? rattle?
2) how do I measure the speaker to buy a foam kit?
speaker diameter? cone diameter? what?
3) if I can live with it, does it further damage the speakers without
the foam?
4) what destroys the foam?
If i just want to replace the speakers, what is recommended. Mine are
9 inches outside diameter so should be easy to find replacements.
Want good enough sound not expensive.
I've re-foamed 6 Advent woofers. The first kit came with shims for the
voice coil requiring removal / replacement of the dust caps. I did it
as instructed and they work fine. Later kits did not include dust caps
so I didn't shim the voice coils. Those drivers also work fine but
took less time. Old Advent drivers have a masonite reducer ring that I
removed on the first set ( kit with shims ). I used silicone bathtub
caulk to re-bond the masonite to the baskets with an army of
clothespins to hold it together while it cured. I don't recall exactly
what glue I used on the cones but it was not rigid white glue nor was
it contact cement but it is flexible. Later (but sill old) Advent
drivers eliminated the reducer ring by altering the basket stamping
and are easier than the masonite units. Figure an hour on each driver
plus any drying / cure time of the glues. It's well worth the effort.
This is way more than I paid but will give you an idea.
http://www.parts-express.com/cat/speaker-surround-refoam-kits/328
G²
