Speaker & Amp Impedance Question
I have some 8ohm impedance speakers and I have an amp that has output of either 50W at 4ohm or 40W at 8ohm. If connect two of the 8ohm speakers to the single output in parallel that would make the total impedance 4ohm. 4ohm is something the amp supports but question is will the speaker support it? because each speaker is an 8ohm speaker so by wiring up in parallel and make it into 4ohms will that work? I'm assuming if i measure resistance across two terminals of the speaker it will read 8ohms and if i measured it after hooking it up in parallel then it would read 4ohms right?
bertus
Hello,
The resistance will measure an other value than the impedance.
You are right about putting 2 times an 8 Ohm speaker will result in a 4 ohm load for the amplifier.
Some bigger speaker boxes can have 2 times 8 Ohms speakers parallel to create a 4 ohms box.
Bertus
For the speaker there is no problem at all.
The limit is on the amplifier's side:
From this data it is (more or less) obvious, that the amplifier' output voltage is limited.
To drive 50 W into 4 Ω the required voltage is V = sqrt(50 W × 4 Ω) = 14.4 V.
To drive 40 W into 8 Ω the required voltage is V = 17.8 V.
If you were to drive 50 W into 8 Ω you'd need V = 20 V.
The amplifier cannot output more than 17.8 V (at least within the limits of the acceptable distortion).
Now, if you connect 2 × 8 Ω speakers in parallel the output voltage will be the same as for a single 4 Ω speaker, namely 14.4 V (the amplifier doesn't "know" that there are actually 2 × 8 Ω speakers). This is less than a single 8 Ω speaker would have to support, therefore there is no danger for the speakers - if they are rated at 25 W each at minimum (the 50 W from the amplifier are split between the two speakers).
Its not dissipated - isnt that when it turns into heat? But the power probably wouldnt get to the speaker, thats for sure.
A speaker and a resistor in series both conduct exactly the same current.
2A in a 4 ohm resistor and in a series 4 ohm speaker drives and heats the resistor with (2A squared) s 4 ohms= 16W and heats (dissipates in) the speaker also with (2A squared) x 4 ohms= 16W.
Since a speaker has a strong resonance you do not want to connect a speaker in series with a resistance or in series with an identical speaker because then the speaker will resonate like a bongo drum.
any half-decent amplifier has an extremely low output impedance of 0.04 ohms or less that damps the resonance of a single speaker.
Is that the electrical delay caused by the coil in the previous speaker?!?!?
Nah I doubt that, that would only be in nanoseconds...
Impedance is a resistance to AC.
A speaker with an 8 ohms impedance has a resonant impedance of about 70 or 80 ohms at a low frequency. When it is resonating then its coil is moving back and forth with its magnet and is becoming an AC generator. The extremely low output impedance of a modern amplifier shorts the generated power which stops the resonation when the amplifier "tells" it to stop moving.
So thats like back emf in motors. Wouldnt the charge generated only be attracted back the opposite end of the coil of the speaker?
With a motor, if you short it then its generated power quickly stops it. The same with a speaker, an amplifier with a very low impedance shorts the speaker coil (a speaker is a motor that moves its cone and the air around it) when the signal stops, then it quickly stops vibrating.
Sometimes I think you haven't understoof the most basic principles of electronics. You do know Ohm's law, do you?
Charge is not generated. What one does when "producing" electricity is to separate positive and negative charges to create a potential difference which we call voltage.
