source for part needed
G
Gaz
Hi
My mate has managed to damage his imobaliser while fitting it.
There is a small black semicircle with the number A733P95C on it
It has 3 legs on it, 1 of which has broken
I am sorry this is all the info he has given me
I am not very good with electrics.
Gareth
CWatters
Not sure but a Google search for "A733 transistor" or just "A733P" reveals
these two sites:
http://www.kristel.com/Support/ay1035.pdf
The above is a circuit for ?? and it shows Transistor Q301 (top right
corner) marked as an A733P. The symbol is for a "PNP Transistor"
http://www.geocities.com/SiliconValley/Hills/5574/power.htm
The above is an "equivalents table" (do a search for A733) and you find
"2SA733P1" in the table for
" PNP Si Transistor, AF Power"
Looking at the table I see that it suggests a BC178 might be a suitable
alternative to the 2SA733P1.
The BC178 comes in several different packages. If you don't get any better
answers to this posting try replacing the broken transistor with a BC178 in
the same package as the broken one.
Colin
W
Watson A.Name - Watt Sun, Dark Remover
Hi
It's a 2SA733P, which is a very common Japanese PNP transistor. The P
on the end means it's the gain range of 200 to 400. The 95C is
probably the date code. The Japanese transistors have the collector
on the center pin, which is different than most U.S. or European
transistors.
See URL http://www.necel.com/discrete/images/pdf_e/TC-3004B.pdf
If you use a BC556B or similar as a substitute, you will have to put
some insulating sleeve over the collector and cross it over the other
lead. The 2N3906 might work if you select one for a gain of over 200.
But you could probably find a real 2SA733 in some discarded monitor or
TV.
I came across this in my googling. At the very bottom, they have a
small strip of a picture of a bare shouldered blonde, with a scroll
bar on the right to get you to try to scroll the picture to see more.
Tricky bastards are just trying to get you to click on the image to
take you to another web page, so they'll get credit for a click-
through and make a few cents. Tricky bastards need a lesson in truth
in advertising.
http://www.electro-tech-online.com/viewtopic.php?t=3863
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
