Source for high-quality 3.5 mm stereo phono jack (PC mount)
Some Guy
Am looking for a high quality (ie reliable) 3.5 mm stereo phono jack
that's PC-board mountable. Basically am looking for the best such
connector available (for under $25 USD each QTY = 100 to 200).
Please post any suggestions (manufacturer, make/model #, etc).
Thanx.
W
Walter Harley
I've been searching for this for about three years now, talking to
distributors, looking through catalogs and web sites, and looking at
equipment. Like you, I'd be willing to pay a substantial price for it.
AFAICT, there are none. That is, there are no 3.5mm jacks that are anywhere
close in quality to what you can easily get in a 1/4" jack.
For instance, neither Switchcraft, Neutrik, nor Rean make a 3.5mm stereo
jack. (Switchcraft claims to, but based on the technical drawings and
samples I've received it looks like they actually buy bottom-of-the-line
Taiwanese product and reship it; don't bother.) Schurter, of all people,
make a 3.5mm jack that looks like the Rean stuff; but it is not
dimensionally compatible with a 3.5mm stereo plug, it's for some different
sort of plug that I've never encountered.
If you must use 3.5mm, then your best bet is probably something like the
Kobiconn fully-enclosed jacks with threaded bushing, as exemplified by
Mouser part # 161-3500. Of all the jacks I've tried, these seem to have the
best construction, best manufacturing consistency, and the most solid
contacts. Interestingly, it seems like the manufacturer name changes every
time a new catalog comes out, but the construction style, technical
drawings, etc. remain exactly the same - at Mouser, even the part number
remains the same.
By the way, if you possibly can, use something with a threaded bushing. I
can't tell you how much gear I've fixed that was mechanically secured only
by the solder joints, meaning that after a couple of years of plugs being
pushed in and pulled out, the solder joint cracks and the equipment becomes
intermittent. It is very important to mechanically secure the jack in a way
that does not transfer stress to the electrical connections.
W
Watson A.Name - \Watt Sun, the Dark Remover\
[snip]
Amen! And that goes for power supply connectors too.
