Sound activated switch
I have a 110V solenoid valve that i want to activate from a sound activated switch. The switch needs to have a timer which will allow it to shut off quickly (1 or 2 seconds). I have found ones that run off 9 volt batteries or low volt,but this needs to control the 110V valve. Does anyone out there have any experience with this type of switch or any suggestions??
Welcome to EP!
Post a link to the 9V switch spec or datasheet and someone here should be able to suggest a way to interface the switch to the valve.
