E
Eric R Snow
I've been fooling around with some tiny vibrating pager motors. These
motors are .160" dia x .625" long with a .028 dia. x .120 long shaft.
In MM that would be 4 x 16 with a .7 x 3 shaft. These tiny things are
rated at 1.3 volts and 65mA. I mounted a relatively large (1.25" x.1")
brass flywheel on the shaft and am now running it at 4.2 volts at
270mA. The motor gets hot with the extra work it's doing along with
the higher volts and amps. As long as the bearings hold up will the
motor life be about the same if it's mounted in a good heatsink to
keep it cool? Will the higher voltage and amperage make the brushes
wear out much faster? I'm looking for ballpark type answers. I know
that without the complete motor specs it is hard to tell exactly how
much the life will be shortened.
Thanks,
Eric R Snow
Thanks,
Eric R Snow
