W
Wdyorchid
Trinitron (kv-27ts20) appears to have lost it's green because I can see only
purple, pale pictures. The problem occurred during a hot scorching day when it
became intermittent then permanent. Is it the tube or the circuit board? I
like to use a test jig tube to find out. I have two 17" Trinitron in the
basement and I'm trying to hook them as a test jig.
The problems are simple. Can this be done if the subject tube does not appear
to be an exact connection match? If so, how many wires jump from one tube to
the other? Four? (Red, Green, Blue and Ground.) Or do I just plug em all in to
the other tube as close to on the labeling as possible. What are possible side
effects?
Example:
Tube one (kv-27ts20) contains about nine pins.
Tube two (kv-xxxx) contains about seven pins.
Tube three (kv-xxx) contains about seven pins.
effects?
Example:
