Ray Carlsen
This Sony KV36FS320 will not power up, just 9 flashes of the standby/timer LED,
unless I press the power button while energizing the power relay manually, ie
Q608 base drive for 1 second. Then the set will run and -everything- works
until I turn it off again. All standby supplies are working, zero cross pulses
are there, and the M board has been swapped. That's where the power-on pulse is
supposed to originate but there is no pulse at power up. I really need your help
with this one. Thanks in advance! Ray Carlsen, A/V engineering, University of
Washington, Seattle
Ray
Washington, Seattle
Ray
