Happy New Year to all at Electronics Point!
A new year and a new repair project beckons.
This project I don't want to spend a huge amount of time nor money repairing it as it belongs to a neighbour. They asked me if I could "take a look", and I said I would. I doubt if the amp unit is worth much nor is it collectible to my knowledge. However, if I can get it working with a few simple repairs/ component swaps, then I can chalk it up as another repair success. If not, it goes back to her and from there likely to the recycling center.
Anyhow, here's what I can tell you about the unit and the fault.
Sony STR-DE305 Stereo Receiver/ Amplifier. Was used in a home setup with TV and CD inputs, and then running to integrated house speakers. Apparently it worked fine until one day it didn't. No other reason given as to why it might have stopped working.
On powering on, you can hear the transformer coils power up, but other than the "bass boost" button on the front panel, there's no other LED's or lights. The bass boost LED turns on and off with the switch. With a CD player connected and playing, I tried to see if there was any output. Nothing from speakers, nothing from headphones. Selecting buttons on the front panel does nothing, therefore other than the bass boost LED/ button and hearing the transformer coils engage, it appears to be pretty much dead.
I have already taken it apart and have noticed what appears to be a suspicious area where there appears to have been some overheating. As pictures speak a thousand words, here's some of the unit and areas of the circuit board.
The unit itself from the front:
Model Number:
![IMG_20180115_230009.jpg IMG_20180115_230009.jpg](https://makerv2.webteractive.co/forums/data/attachments/37/37074-800764142072b3b098a3ce1602d98946.jpg)
The only LED that works, and the only button that appears to do anything (bass boost):
![IMG_20180115_230021.jpg IMG_20180115_230021.jpg](https://makerv2.webteractive.co/forums/data/attachments/37/37075-949c41754855756ca023f03c60de5699.jpg)
From the rear:
![IMG_20180115_230042_1.jpg IMG_20180115_230042_1.jpg](https://makerv2.webteractive.co/forums/data/attachments/37/37076-27352db169369120f223b0035ddd35b1.jpg)
With the top case removed, a view of the main circuit. Transformer and large capacitors to the left, controller circuits/ inputs to the right. Small satellite board on the right is connected to the volume control. There's another board this connects to, which is the main display and all the front panel controls (between the long silver panel and the black plastic front cover).
![IMG_20180115_230341.jpg IMG_20180115_230341.jpg](https://makerv2.webteractive.co/forums/data/attachments/37/37077-a83b35f43f26ed11cd5cedfb1a7902f9.jpg)
Closer view of the right hand circuit:
![IMG_20180115_230350.jpg IMG_20180115_230350.jpg](https://makerv2.webteractive.co/forums/data/attachments/37/37078-a71f5fdfc5bc1906dfe3814e630d44c7.jpg)
Another view from the rear. The smaller circuit board suspended above the main board and connected via a ribbon cable is connected to the front panel and the volume knob:
![IMG_20180115_230358.jpg IMG_20180115_230358.jpg](https://makerv2.webteractive.co/forums/data/attachments/37/37079-4c2619f33f64afeb9bc68b13ad40c547.jpg)
Closer view of the small board connected to the volume knob:
![IMG_20180115_230406.jpg IMG_20180115_230406.jpg](https://makerv2.webteractive.co/forums/data/attachments/37/37080-bc052ba7afb90f6611e2d4b7ca3721b6.jpg)
On the underside of the unit is a removable screw on access panel. Taking this off shows the underside of the circuit (controller board/ right side). This seems to show a couple of areas that might be where the problem(s) lie, appearing to show some areas of overheating:
![IMG_20180115_230710.jpg IMG_20180115_230710.jpg](https://makerv2.webteractive.co/forums/data/attachments/37/37082-d482928b2214e46bd1882c4c8b3af7d0.jpg)
Larger suspicious area appears to be the IC-701:
![IMG_20180115_231014.jpg IMG_20180115_231014.jpg](https://makerv2.webteractive.co/forums/data/attachments/37/37087-74908e1460127886d96ace4a3220d80d.jpg)
This is the IC701 as viewed from the top:
![IMG_20180115_230833.jpg IMG_20180115_230833.jpg](https://makerv2.webteractive.co/forums/data/attachments/37/37084-d469872613dbe30a7c97954514108296.jpg)
IC701 is an NEC uPC2581V 9607B. Plenty available for sale online if this is what I need to replace.
Here's the other area that shows signs of overheating:
![IMG_20180115_231031.jpg IMG_20180115_231031.jpg](https://makerv2.webteractive.co/forums/data/attachments/37/37088-1e6e478e6b68cf2ed0b125dec13db02a.jpg)
Q803, Q703 and some diodes/ other areas look suspect also.
Here's the view of Q803 and these areas from the top:
![IMG_20180115_230908.jpg IMG_20180115_230908.jpg](https://makerv2.webteractive.co/forums/data/attachments/37/37086-7358f9aa846478c4374c48694d65f570.jpg)
Some odd looking black lines to right of Q801 and to the right of R807. No idea if they are simply marks on the board or if they are from components that have gone "pop".
Would be very grateful for any pointers as to where I should start looking, testing, and what components I should replace. Most of the components are pretty much standard and my soldering skills should be sufficient to replace most components on the board. Also, if any other pictures are required for further details, just ask and I will happily take some.
Looking forward to hearing some wisdom from the Electronics Point Gurus!
![IMG_20180115_225958.jpg IMG_20180115_225958.jpg](https://makerv2.webteractive.co/forums/data/attachments/37/37073-fa239ebcf2b62f8ae5a7be5861afbb9c.jpg)
Model Number:
From the rear:
