Sony SLV-750HF won't rewind
Sam Hathaway
I'm trying to repair a second-hand Sony SLV-750HF. It's much nicer than the
mono JVC unit I'm using now, and I'd really like to be able to use it.
The problem is that the supply reel won't turn in reverse. This causes
rewinding, playing in reverse, and ejecting to not work. The tape just
piles up inside the deck -- no error codes.
I replaced a broken supply capstan gear, but that didn't fix the rewind
problem. All the visible gears in the little "transmission" between the
reels (what is the correct term for this?) seem to be in working order. The
unit is fairly clean.
I've taken the top cover off of the "transmission", but I'm hesitant to
take the bottom cover off, since it looks like a thousand tiny parts will
come flying out. Does anyone have any ideas?
Thanks!
-sam
W
Walker
Sam Hathaway said:
Thanks!
This may help some.
http://www.fixer.com/dbase/sony/slv750hfs5.shtml#TAR2
Sam Hathaway
[/QUOTE]
than the > mono JVC unit I'm using now, and I'd really like to be able to
use it.causes > rewinding, playing in reverse, and ejecting to not work. The tape
just > piles up inside the deck -- no error codes.rewind > problem. All the visible gears in the little "transmission"
between the > reels (what is the correct term for this?) seem to be in
working order. The > unit is fairly clean.to > take the bottom cover off, since it looks like a thousand tiny parts
will > come flying out. Does anyone have any ideas?
Thanks for the pointer. I took a look at that page, but it doesn't look
like half load arm is the problem. It really looks like it's a problem with
the supply spindle(?) itself or one of the gears that drives it.
-sam
