Sony Service Menu
Chris F.
How do I access the service menu on a Sony KV-20S10? I tried the usual
PWR-ENTER-5-VOL+-PWR but it won't access it.
Jixter
Not sure if this will work for your TV or not.. It's for a slightly
different SONY TV
1. Standby mode. (Power Off)
2. DISPLAY --> 5 --> VOL(+) --> POWER on the Remote Commander (Press each
button within a second)
I take NO responsibility for any damage or loss of productivity for
supplying this information to you or anyone who reads this.
Jixter
Chris F.
Already tried that, in fact I've tried every combination of those keys I can
think of.....
different SONY TV
Jixter
Travis Jordan
I don't have the manual for that set but some of the early Sony's had a
service mode switch on the rear panel.
Andy Cuffe
Look for a hidden button on the back panel near the A/V inputs. With
the set turned off, press and hold it while turning the set on. It
will operate exactly the same way as newer Sony's in service mode.
Andy Cuffe
[email protected]
Jerry G.
On the series of set you have, Disply, 5, Vol+, PWR should do it. Press
Mute, Enter, to save your damage.
Take care, that many of the adjustments require the proper test
facilities to properly calibrate. Only a small number of them are done
visualy. There are no default settings. These values are adjusted to
the particular set's characteristics. Some settings can actualy go out
of range, thus making the set non accessable any more. The set would
require proper shop service to get it working again.
The service adjustments are factory set, and should not have to be
modified after manufacture unless critical parts have been replaced.
If your set has a fault and was working before, then proper service
should be done to repair the problem.
Jerry G.
Similar threads
