Chip
Need some direction.. Have sound but no raster..
I started with a convergence problem, replaced both of the SKT's on
the D board along with two 1/2 watt resistors that burnt. Same
problem existed.
Started to look at the PIN output circuit and then things got worse.
I was unable to power-up. I assume I contributed to the failure as I
left a ground off of the HV block.. I replaced the Horizontal Output
Transistor and was then able to power-up again.
At this time each of the CRT's have 233 volts at the filaments, and
are lit. You can see a horizontal line with noise if you look
throught the lenses of each of the CRT's. I assume HV is there. I
ESR'ed all caps on A, D and G boards, and checked the associated
transistors, all look good.
Still no raster. Also tried another input device with no luck. No
menu display either.
The SKT's have the appropriate -+18 volts, checked vertical IC
voltages also look good, but seem to be running hot.
Where do I go from here??
problem existed.
