Sony KV32TS35 no vertical deflection
G
Golf
The set has no vertical. High voltage is OK. I replaced the vertical
IC, but no help. I resoldered the jungle IC and deflection plug also. I
don't have the schematic for this set, but I have checked all
electrolytics in the area only for value. My ESR meter is on loan to a
local shop. Since I am a beginner, and don't have much experience
troubleshooting vertical problems, I was hoping someone has experience
with this particular model and could point me in the next direction.
Thanks as always.
E
Erich J. Schultheis, The Man with the 15 inch Cock
If you're a beginner, then take it to a shop, perhaps the one that took
your ESR meter. There is enough high voltage in those cocksuckers to
burn your nuts off to the floor.
