James Sweet
This set has a SCC-S47B chassis, odd symptoms in that when powered up
there is no HV, however when turned off the HV spikes to several KV for
just a moment as the thing is turning off. No diagnostic codes are
displayed on the LED and I've looked pretty closely on the deflection
board and retouched a bunch of solder joints but nothing has made a
difference yet. Looking at the HV driver IC I'm seeing 0 and 3.8V on
pins 1 and 2 respectively which should be 2.5 and 1.8v. Pin 7 has 0.1
but is listed as 4.0. Pin 12 is 0 but should be 4.6, pins 14-16 should
be around 160v but instead are sitting around 10v and pin 18 should be
1.7v but is instead 202(!)v. Any ideas on what to try next?
