Tom Knowles
This set works perfect for about 1/2 hr. then turns itself off. If
it is turned back on it runs for about 15 min. Then if turned back on it
runs for about 7 or 8 min. Finally after doing all of that it won`t turn
on at all, until it apparently cools off.
Sony says it is the D board, which is about $300.When you look at
the board you can see why.
My question is, has anyone had a similar trouble as mentioned
above and gone into troubleshooting the board for a particular component
failure? From the physical layout and size it looks as this would be a
very difficult thing to do unless you know which part is the culprit.
Any replies on this would be appreciated.
Thanks Tom
Thanks Tom
