Sony HCD-H5
I have an old Sony HCD-H5 deck, European model.
It doesnt power on and after searching the web I found a post on this site (very old) that says it could be either or both:
  • bad 5v power regulator
  • leaked transistor
I have the service manual.
Appreciate any guidance in locating if the above 2 issues could be the problem. Starting with the power board, where do I look first?
Id start something like visual inspecting the board.
Most of the problem i solved like that,sign of damaged,fried or loose connections.
Im not an expert,just trying to help, maybe i inspire to for another idea :)
open it up take a visual look at where the power socket goes into the pcb and have a look to see if there are burn marks around hat area. a few pics would be good to put up for us to take a look.
800ma fuse blown
Don't forget checking the fuse.
Thanks!
The 800ma fuse on the power board was blown. I'm getting a delay 800ma 250v (same rating) replacement. The other 1.6v fuse is fine.
I'm hoping the transformer is ok, because there are no leaks or burns anywhere.
Thanks again.
