I cannot tell you the exact parts in your monitor. There are many components
that can cause this. The fault is most likely in the vertical blanking
circuits, or in the feedback section of the vertical amplifier section
(causing a vertical blanking phase error). If the vertical blanking drive is
not properly biasing off the CRT during retrace, these lines will be
visible.
Another cause is that the CRT can be going weak, and thus not properly
responding to the blanking bias during the retrace period.
The expensive part of this type of repair is the labour, unless the CRT is
defective. The tech can easily spend more than an hour or two to
troubleshoot for the defective components, and then have to change them.
If you look at the labour cost per hour in your area, this should give you a
good idea of the basic cost for servicing your monitor. Calculate this based
on 2 hours to be safe. As for the parts, if it is a number of small
electrolytic capacitors, the parts cost can be from about $3.00 to $20.00
depending on the amount and the types of capacitors.
In most shops where we are, this would cost about $80 to $140 average, as
said, depending on the exact nature of the fault. This is considering that
the parts involved are also as mentioned.
In my opinion, since I know of this model of monitor, I would be considering
a new monitor. After servicing it, if you consider the age, there is the
potential reliability factor to consider.
A 19 inch LCD pane. would be equivalent to about a 21 inch CRT monitor.
There are many advantages of an LCD screen over a CRT monitor. One of the
main things I like about the LCD monitors, is that there are no convergence
or purity errors.
With LCD monitors, there is no eyesore caused by the scanning electron beam,
and the UV emissions from the screen surface. These monitors are considered
much healthier for the users. If a woman is pregnant there is no worry from
any electromagnetic radiation, or X-Ray emissions. LCD monitors typically
draw about 1/3 to 1/4 of the power consumption, and have no high voltage, as
like in a CRT monitor.
The prices of the LCD monitors are lower than that of the equivalent CRT
monitors of only a small number of years ago.
