Steffen Moser
Hi all,
I've got a problem with my 21" CRT monitor "Sony GDM-F520".
I've been using this device for about eight hours per day since
I bought it in November of 2001 (it was manufactured in September
of 2001 as the type label states).
The monitor has been working all over the time without any
problems, the quality of the picture is still excellent (very
high purity). My OSD brightness and contrast settings are both
at about 50 %. I didn't have to increase them much, yet.
But for about a few weeks I have noticed the following problem:
Although the monitor itsself does still work perfectly (i.e.
it displays the picture as usual), I can sometimes hear a kind
of "crackle" noise (not very loudly!) immediately after warming
the monitor up (it takes about 10 to 15 seconds) after powering
it on.
Together with this crackle noise the picture is flashing in red
color.
It doesn't happen regularly and if it happens, it won't happen
more often than about one or two times - and only after powering
the monitor on (or leaving the energy saving mode). I haven't
noticed it during operation, yet. It seems to me that it
especially happens when the device hasn't been in use for some
hours (i.e. has been cold).
I think I should add, that the monitor has always been making
gentle crackle noises after powering it on or off (as it did
almost every CRT monitor or TV set I dealt with). But the red
flashing which goes together with the noise haven't been until
it appeared the first time a few weeks ago.
My questions to you would be:
- What could that problem caused by? For me, as a layman re-
garding monitors' and CRTs' internals, the noise sounds like
a eletrical discharge (as if very little sparks are jumping
over). I have tried to look through the louvers (having the
room darkened), but I didn't see any sparks but only the
glowing of the CRT's heating.
- Is this maybe a common problem with the Sony GDM-F520 or
other Sony CRT series?
- Do you think that the appearance of the problem will increase
and it's a "omen" of the monitor's soon death?
- Do you think that bringing the monitor to a repair shop (or
even to Sony's service) is a worthwhile thing?
- Is there anything that I can do myself? At least, I can
imagine that the discharges could be caused by dust. Is this a
typical problem and would dust let the monitor react that way?
So, do you think that there a good chances that opening and
cleaning the device can solve it?
I'll appreciate any help and thank you very much in advance!
Best regards,
Steffen
it on.
color.
Best regards,
Steffen
