Z
Zev Berkovich
I have a question that I hope someone might be able to help me with.
I recently received a Sony CDP-CX255 200 CD changer from an
acquaintance.
He had this CD player hooked up to a second 200 CD changer, along with
a complete Sony system.
He told me that he had been using the player through his Sony system
remote control, which I'm sure you are aware hooks up with cables to
the back of every Sony stereo component.
My stereo system is a Kenwood, so obviously Sony system controls will
not work with it. Nonetheless, I have attempted to use it with both a
Sony remote control (it has an infrared receiver), and using the front
panel controls. Neither of them seem to have much effect.
The symptoms are:
The changer always stay "on", however the power light over the power
button does not light up.
The changer will load up CDs, and rotating the turtable control knob
will rotate the turntable.
I have opened the unit up, and found that when you close the front
loading door on the unit, the turntable will rotate and then load up a
CD into the player. However, the CD does not spin at all in the
player, and pressing play does not seem to have an effect on playing
the CD.
The other symptom that it had is that the "System Link" selector
switch didn't seem to function properly. It would show CD2,
regardless of the switch position, and occasionally would switch to
CD1, and then back to CD2 on its own. I managed to clean the switch,
and now the display matches the switch setting.
Note: While writing this message, I tried a few things.
after this cleaning and a bit of other fiddling around, there seems to
be some response from the actual CD player unit. If I move the laser
pickup away from the centre of the CD (with the power off of course)
the pickup motor will actually move the head back to the centre when
it loads a CD. So that part seems to be functioning. As well,
instead of the CD staying loaded as it did before, the changer will
move on to the next CD in a few seconds, as if it didn't recognize the
disc. This will keep on going for each CD on the turntable.
The power button now works as well.
Anyways, if anyone has ideas on how to repair this problem, I would
certainly like to hear them.
Thanks,
Zev Berkovich
Toronto Canada
acquaintance.
The symptoms are:
the CD.
Thanks,
Zev Berkovich
Toronto Canada
