Sony 5 DVD compact home AV receiver model:HCD-C700 (DAV-C700)
(DAV-C700),year:March 2001.No DVD tray eject,display reads "open"
but nothing happens.When I remove the cover and then the dvd cage cover
the unit opens and closes properly but once I put the DVD cage cover
back on it does not,it's driving me crazy anyone have any common
repair tips for this high end unit? which the customer paid $1100 three
years ago.Thanks in advance.
Sidney
Dartmouth,Nova Scotia
Canada
Mark D. Zacharias
Sidney
Canada
SYMPTOMS
No Operation in DVD Mode or C-81 error is displayed.
CAUSE
Transistor Q002 malfunctions.
RESOLUTION
Replace Q002 with HOUSING (Q002) ASSY which consists of a higher capacity
transistor (2SB1375), and socket. Also replace R011 (1K ohm) with a 470 ohm
resistor.
New part number for the transistor is X-4954-896-1.
Resistor part number is 1-218-949-11.
The resistor is about the size of a flea speck. Better to just solder a 1
kOhm 1/8w resistor across R011.
Mark Z.
Mark D. Zacharias
Sidney
Canada
P.S.
These models are so unreliable, it is very possible you will work hard to
get it running, then the customer will be back in a matter of weeks with a
similar but different problem, and of course it will be your fault.
Mark Z.
