Sony 41" intermittent convergence
X
XrX
I've never posted to a newsgroup (I'm the ultimate lurker), but I've
run into a problem with my 7 year old 41" Sony KP projection
television that has only seen about 4 hours of use per week. Maybe
someone here can offer advice...any of which is very, very much
appreciated.
For the last 3-4 months, the television would occasionally drop out of
convergence (the red image would drop about 6 inches and bow some).
Turning the television off and on would fix it most of the time. More
recently, it started happening and it would persist. When turning on
the television a thin greenish bend appears in the top 1/2" of the
screen when it doesn't work.
So, I pulled the television out and unplugged my X-Box, Tivo, ect and
set it aside. In an effort to get a picture of it, my kids and wife
used it for 6-8 hours and it never did it again. Strange. The picture
still looks good.
Does anyone have any thoughts from here? I'm willing to open it and
solder loose connections if that might be the case but I wasn't sure
if that could be it.
Thanks!
HC
I
ian_tech
popssibily of bad joints on the convergence pcb at convergence ic's or a
bad capacitor into power supply.
Jerry G.
This is most likely cold solder connections on the convergence board, or
some failing components in the convergence circuits.
Jerry G.
appreciated.
still looks good.
Thanks!
HC
X
XrX
Thanks Jerry!
"cold solder connections"
I'll look around the d board behind the speakers. Are these easy to
spot? (a cold solder connection)
bobinphx
yes,they are easy to spot, with a magnifying glass. Look for shinny
connections (good) and dull silver connections (bad) and any leads that the
solder appears not to have adhered to.. of course if its surface mount,,, I
have no idea what to look for (I hate surface mount things!!!)
Bob in phx
