sonar object sensor/ buzzer ciruit design
I don't know where to begin in designing the simplest possible circuit with a sensor and audible alert.
Miniature.
Thank you.
Roonie
davenn
hi there
welcome to the forums
do a google search on ultrasonic transmitter and receiver circuits
its the obvious choice
Dave
KrisBlueNZ
Sadly passed away in 2015
Very important! What do you want to sense?
Welcome to the forums :)
You want something small and simple? Think of the power source first. Two 3V lithium coin cells produce 6V which can operate some loud piezoelectric beepers!
You don't say where you are so I'll assume America. The big parts suppliers there are Digikey and Mouser, and a few others (
Here's how to use the Digikey search filter engine. Go to http://www.digikey.com/product-search/en/audio-products/buzzers/
Narrow down the featuers you want by clicking in the columns to enable (select and highlight) or disable (deselect) an option. (A column with no options enabled has all options enabled.)
Driver circuitry: select "Indicator, Internally Driven" and "-". (Use Ctrl-click to add/remove a line from your selection.)
Supply type: select DC only.
Voltage - Rated: select 5V and 6V options, or a wider range if you like; 6V may turn out not be an ideal supply voltage.
Mounting type: leave all these types enabled. Surface-mount components will be compact but other types may have physical advantages too.
Other parameters choose now or narrow your filter later.
Select In Stock and click Apply Filters
Scroll down to see all the options that match your filter.
How you turn the beeper on and off is the interesting part of the project. You need a sensor, and probably circuitry of some kind, to process the sensor's signal (it may be an analog signal that needs some kind of detection process to know when the conditions are right to activate the beeper.
Low-voltage low-power circuitry like this often uses MOSFETs with low gate voltage thresholds for the active elements. It all depends entirely on what you want to sense, and how you want the beeper to respond.
BTW it would be very helpful if you told us some background information about this project! It sounds like an exam question to me... Prove me wrong!
Thank you so much, Kris and Dave.
You are most kind for getting back with me!
My project is to design a sensor which sets off an alarm when an object is detected.
I know about piezoelectric buzzers, but it musn't be too loud, and the sensor neds to be sonar instead of infrared, since it is for outdoor use.
I know they have these devices available for installation on car bumper systems (for backing up warning). But I want to understand the schematic of a very simple design of such a circuit.
Can you help me connect the dots?
Thank you!
Roonie
KrisBlueNZ
I don't know much about it, I'm afraid. I have played around with ultrasonic movement detection using the Doppler effect but your requirement is different - you want proximity detection.
I would start by Googling the important keywords:
http://www.google.com/search?q=ultrasonic+object+promimity+detection
I think the needed complexity of your design will depend on the operating conditions and performance requirements. Things to focus on would include the range required, the breadth of coverage, the exact parameters that define whether something is detected or not, and the size, shape and material that needs to be detectable. If you have a large standard object with a hard, flat surface, a simple received ultrasonic signal detector might be enough. If you need to calculate the distance to the object, you will need some kind of timing method.
Good luck!
