Platforms
Content
have a Panasonic message chair a relay on the circuit board continuously clicks. Chair not working. Where to start what may be causing the relay to click
The model # EP1015Start by letting us know the model number.
What makes a relay click?
First thing is to identify it and the function it performs in the circuit.
LOL,Maybe the message chair is sending its messages as Morse code?
We need to find the service manual or the schematics.The model # EP1015
How do I tell what function it performs. I know not so much about circuit boards almost believe morse code haha
It's one of three relays it's very hard for me to tell any ideas I found a service manual on the web I will try and post the link soonWe need to find the service manual or the schematics.
You should tell us the part number identifier of the relay on the board.
Here is the link for the service manualIt's one of three relays it's very hard for me to tell any ideas I found a service manual on the web I will try and post the link soon
View attachment 26459 View attachment 26460 View attachment 26461 Here are a few pics of the board. I wish I could tell which one. Is it possible all of them?
No need to bet.If I were a betting man I would say it's the smaller one by itself RY503
Ok I did that it is ry503No need to bet.
Put your finger on the black plastic casing (without touching any thing else) ,
you will feel the clicking one very clearly.
What color is the rectifier and please explain how to test it. And which one is fe502 and how to testBefore you removed it, i would simply place my finger on top of each relay until i felt the clicking
Check fet502 and the other transistor (see if you get any shorts)
Maybe, can't tell from the picture but there looks like a bridge rectifier next to the fet502 ? If so check that as well, when powered up you will see AC one side and DC the other, make sure that's working..
Sorry I don't know much about circuit boards and components but I am willing to learn. Still need help I appreciate all the help to this pointHere are a few pics of the other side of the pcb. What does the D502 Q502 and R502 signify
View attachment 26467 View attachment 26467 View attachment 26468
Minder here is a picture of the board in question can you please point out which one is a diodePresuming the relays are DC operated, I look first for the usual diode placed across the coil, it is usually adjacent to the relay, a meter across the diode when the relay is activated will sometimes tell if it is a low voltage problem, or the device operating the relay is turning on/off, relays click or chatter because one of these two reasons.
They show as 5v DC type.
A place to start.
M.
