Z
zalzon
Hello,
I've always dreamt of inventing little gadgets & gizmos so
one day, I started on an introductory electronics course (found on
twysted-pair's website).
Though I am determined, learning electronics is a little tougher than
I expected.
Now for the questions :
1) Do you think the course I am learning gives me most if not all of
what i need so far as analog electronics goes? Please take a look at
the lesson topics :
http://www.twysted-pair.com/downloads.htm
Do those topics cover all the essentials of analog electronics or is
there another motherload of theory to absorb once I'm done with that.
2) Do electronic engineers building say robots or cell phones use
mostly analog or mostly digital electronic components in their gizmos?
Does industry require electronic technicians/engineers with mostly
analog or digital skills?
3) Are there a certain number of important circuits which are commonly
used in design of electronic circuits. Could you list them.
4) When you look at a complex schematic, where does your eye look
first? How do you analyse what is happening in the middle of the
circuit for instance? Do you start at the power supply and move to
the middle. Do you "chase the flow of electrons" in the circuit to
understand what's going on at every point. Or do u take a nebulous
view of it? Or do u view it in blocks and say 'here's the common
emitter amplifier', 'here's the full wave bridge rectifier', here's
the whatever..etc. ?
5) I often see current being represented as a flow from + to - and the
direction of the arrow is usually that way in text books. Whereas I
tend to think of current as a flow of electrons from the ground up to
the positive. Is this wrong?
6) Are microchips, fpga, asics..etc all based on the same principles
of analog electronics. I know there are transistors on a microchip
but are the principle of operations the same as how I"m learning it?
I have more questions but I'll stop here.
Thanks, i hope these are not silly questions.
I expected.
the lesson topics :
