mowhoong said:
I intend to purchase a micro switch. According to the previous
product spec., it states 6A250VAC,10(1.5)A250V. I 'm confused that it
shows two diffrent spec. Can any person
help me in this question ? Thanks
The problem with micro switches is that there may not be
much air space between open contacts, so they tend to draw
an arc that damages the contacts. This is especially bad
with inductive loads and DC voltage. AC voltage keeps
passing through zero twice per cycle, so that helps limit
the time an arc will continue.
I think the first pair is the AC rating. 6A with up to 250
volts AC.
The second set is probably a DC rating (V, not VAC), 1.5
amps with an inductive load, or perhaps an incandescent lamp
load (that produces something like a 10 times inrush when
the filaments are cold) and the 10 amp rating is for a pure
resistance load like a heating element.
In all cases, the ratings are for some (reasonable) number
of operating cycles. The switch will last a lot longer if
you load to only about half of these ratings.
