Solenoid PWM high side driver HELP/ADVICE
E
Elektro
I'm going to make a PWM high side driver for a solenoid. And now
I'm wondering what good or bad happen if I select a 20 kHz PWM
frequency instead of 2 kHz?
At 20 Khz I have lower inductance and higher serial resistance that at
2 kHz. Does this lead to more heat in the solenoid coil?
And I also assume the driver P-channel MOSFET transistor gets hotter at
20 kHz?
Is the coil current step response the same?
Anything else?
The reason for 20 kHz is that it's non audible.
E
Emanuele
20 kHz?
Anything else?
I don't known Your application
but the only disadvantage is the harmonic emissions in EMC compliance
(if it's a power application)
You know the advantages already
Emanuele
*** YOUR ELECTRONICS OPEN SOURCE ***
http://dev.emcelettronica.com
Progetti Completi (Full Projects):
[IperKEY-ResKEY] Chiave elettronica a microcontrollore
(Microcontroller Electronics Key and key reader)
//TAGS:pic, Eeprom, ADconverter, I2C
[IperCODE] Ricevitore RADIOCOMANDI e decodifiche
(Remote Control Receiver and decoder)
//TAGS:pic, Radio control, routines, rolling code, UART, CCP1, LCD
[GSM] Risorse e firmware per GM862 TELIT
(GSM resource and firmware example for GM862 TELIT)
//TAGS: Pic, GSM, TELIT, GM862, Mobile Control, routines, level shifter
John Popelish
20 kHz?
Anything else?
The main drawbacks of low frequency PWM are audible noise
and larger ripple current in the inductance. The turn on
losses of the switch will be lower, because they take place
at the lower minimum current, but the switch off losses are
higher because they take place at the higher peak current.
But, in general, since many switching losses are a per
transient accumulation, lower frequency means lower
switching losses.
Higher frequency can raise the core losses through eddy
current increase, but this depends a bit on the core
material and shape. This effect can be mitigated by adding
a low loss (at the fundamental and first few harmonic
frequencies) inductor in series with the load, so that most
of the high frequency content can be dropped across that,
instead of your solenoid. And, the switching losses are
higher at higher number of switching events per second. But
if other concerns mean that you have to go with the higher
frequency, you can move some of those losses to a snubber,
to keep the switch cooler. Regardless, at higher switching
frequency, turn on and turn off times become more
significant, and if you speed those up, dramatically, to
keep the losses down, you may have to deal with higher EMI.
As you can see, there are a lot of factors to balance to
come up with the optimum switching frequency.
