jw
I just was able to solder an miniature 8 pin SMD part and I thought it would
be useful info to someone who's trying to do the same - it's hard to do.
The pads are 0.5mm apart and 0.2mm wide. I had to design the part outline
myself for the PCB then I had it produced by a service.
First I went and bought a soldering iron tip that went to a 0.25mm tip.
I also got some silver solder but I doubt this is necessary.
Then I glued the part onto the board with rubber glue, just enough and no
more.
I hold the board in a small plastic vice grip underneath a magnifying stand.
Also I'm wearing 2X plastic eyeglasses looking thru the magnifyer.
Then I slathered the pins with the goopy rosin.
Then melt just a pinch of solder on the tip and apply the tip to the pins
for a sec.
Then remove all the solder you can using a copper wick with the goopy rosin
on it.
Then completely remove ALL the solder from the tip and worry off the rest of
the extra solder on the pins using both broad horizontal movements with the
length of the tip, and then using the point to go inbetween the pins when
needed.
Then I have a 15X photography magnifier to examine the part to be sure there
are no shorts.
-voila, jw
more.
for a sec.
on it.
needed.
are no shorts.
-voila, jw
