I would like my PCB would look line more pro so I wish to be in green or red paint like industrial PCBs are, but I don't want to use paint sprays.
I need a solder mask that will be applied to PCB after etching process is done but before soldering the components to the PCB, so mask should not be where solder will be applied to the PCB.
I searced the internet and I found that this is called solder mask. The purpose of solder mask should be to protect against arcing, abrasion, moisture and chemicals. And on the other hand I read that solder mask is used before wave or reflow solderng to prevent connections to be coupled together.
Now I found some solder mask on Farnell site and on Ebay, but don't know if that is what I need. I also found some video on Youtube that shows how I wish my PCB looks like.
So I ask you if you could help me find what I need. Should I look for UV or photo-imageable solder masks and what does temporary solder mask mean as it is written in datasheet for a solder mask I found on Farnell site.
What is used to develop (remove) a solder mask after it has been exposed to UV light - maybe NaOH?
