Hello forum,
I am in a competition for an electronics course to design and build a completely solar powered race car. I have a very basic knowledge of motors and micro controllers so I am seeking some wisdom from more experienced ones! I am an electronics enthusiast and very interested in the learning this competition is going to result in so I'm not looking for someone to do ALL the work for me but i appreciate any help you can give.
To begin with the components we have to use are:
1 - solar cell (4.2V 22mA)
7 - 4700uF, 6.3V capacitors
That is the solar cell we have to use and that is the maximum amount of capacitors we are allowed to use. Lower capacitance capacitors can be used with approval. Any other components are allowed to be used. I haven't SEEN the race track yet but after doing some careful questioning I believe it is about a 50 metre two lane design with lights over the entire length of the track to power the cars. The cars usually move in short bursts, alternating between charging the caps and discharging until the fastest car passes the finish line. Round robin tournament style with best 2 out of 3 advancing.
So I have no experience in electronic race cars or harnessing solar energy and there is so much information online I have fruitlessly waded through that I have decided to come here! Some questions I have are:
Race Car Body
What kind of materials are best? Balsa wood? Sytrofoam?
I assume the cars will be moving too slowly for aerodynamics to make much of a difference. Can anyone verify this?
What are some things to be careful for when building the car? ex. wheel alignment, axle friction, gear ratios, belt slippage etc. and does anyone know exactly how much these things affect speed or know where I could look for the information?
Electrical Design
Which kind of motor should I use? There are so many different kinds online I have no idea what kinds of voltage, torque or current requirements I should be looking for.
Should I be going for high acceleration and coasting? Or try to run the motor as long as I can on a charge?
Are smaller or less caps beneficial at all?
What kinds of microcontrollers are typically used in this situation? Which program would I need to program it?
What exactly does a MPPT do? How would I incorporate this?
Are there any tips or tricks anyone knows to get a bit of extra speed?
I welcome any and all responses.
Race Car Body
Electrical Design
