Hello Electronics Gurus, I need some help with this. I had planned to use the following rigs throughout a HUGE empty building to breathe some life into it.
The assembly seemed simple enough, and cheap enough, until I added the inverters.
I also can't find anything to do variable pulsing with. Ideas? Clues?
The inverters use so much juice, I need to keep them off, via AC timer (?) and run the lights only for 4 hours (8pm - midnight)
[assembly] =
solar panel + deep cycle battery + inverter + splitter/powerstrip + timers + variable puls'ers + color floodlights
Can anyone help? Advice? Some have said I should bag the inverters alltogether and run the whole thing DC, but are there variable DC timers and puls'ers?
Thank you!!
[assembly] =
Thank you!!
