I’m just starting to build some boards specifically using MCU's
and other components, some of the components I wish to use only come in
fine pitch SMT packages. I have looked into reflow and how the
components are normally attached to boards using solder past (solder
cream) and then put though a oven that controls the heating up and
reflow and cool down process carefully. I noticed that most components
im looking at have a heat up to 150Ëš C at 1 to 3 degrees a second to
ensure not to damage the component. Now as far as I can see I only have
2 options to using such components:
1.) build a small reflow oven that is computer controlled and can be
programmed based on the components I’m using, this option is not
expensive but is extremely time consuming.
2.) pay for a shop to fabricate the boards (which is expensive when
dealing with small quantities).
I was wondering if it’s possible to place such components using a hot
air pencil, but these will obviously heat the component up very
quickly, based on the reflow specs I assume this would damage the
components?
Any other fast and not so expensive options?
Thanks for your time.
components?
